Hi, mobile search wont work on my website http://www.gadgetgekkies.nl. It will show the results in but if i hit ‘search’ the URL changes in https://gadgetgekkies.nl/?s=test but im just getting on my homepage.
The same happens on my website http://www.internetgekkies.nl.
What can i do?
Hello @gekkies !
The URL is changing depending on what you search for. Do you mean anything else?
In order to avoid misunderstandings, please provide more information(screenshots/video) about what exactly is the issue there and what exactly you need to achieve.
Hi Bettina, i know it changes but it wont show the results but just the homepage: Again, This only happens on mobile. Check the video to see what i mean: https://www.youtube.com/shorts/GQQOfE19Zh4
Hello @gekkies !
Do you use the posts loop element? Also, without any value in the offset field.
Check on your mobile viewport:https://www.screencast.com/t/XDQJedlggSB
Hi bettina,
Yes: https://app.screencast.com/GvbgZDvhPxInl
It still won’t work. Sometimes it does, but then my homepage chaches the search URL and then my homepage is suddenly the search result.
Hello @gekkies !
Sometimes, the issue can be from a plugin conflict or a cache issue. That’s why we recommend first deactivating ALL plugins except tagDiv ones; if you are using a cache plugin, deactivate it, clear all cache (also from your browser), and see the results.
Hi bettina,
I already did this nut it did not work. I use Newspaper on more of my websites and it all works fine there. Only for gadgetgekkies.nl and internetgekkies.nl it wont work.
If I request the search result, the URL does refresh, but the URL simply displays the homepage. Please check my video.
I have deactivated all plugins, cleared the cache, and the same thing happens.I would like to see a solution, please
Hello @gekkies !
If you want, we can take a look, see exactly the issue and let you know what you can do there. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cpanel url and credentials
Hi Bettina,
Now the search results took over my homepage, and this happened when all of my plugins were disabled: https://youtube.com/shorts/p1S2rjI2Twk?si=8_g6ppnF4f-P_vb5
I dont have a cpanel as i have a custom hosting.
I can give you the admin credentials, wich website do you want? I have it on gadgetgekkies.nl aswell as on internetgekkies.nl
