Hi there,
Since updating to the latest version of Newsmag, memorial site is not displaying correctly.
If you undertake a search for my site on a mobile device, and then click on the search result, the site that comes up has several problems. My slider and modules don’t show, but the code can be seen. In addition, if you go to the menu, only pages display—none of the posts are available in the menu.
At the bottom of the page, there is a link that says View Full Site, and when you click on this is takes you to the previous version of the mobile site, which displays perfectly well. However, my concern is that when people search on Google, the site that comes up in search results is the incomplete version described above.
I would regretful for you assistance, as it is of course very important for us to have a functioning mobile site when it comes up in search results.
My site is called Expat Essentials and the URL is http://www.expatessentials.net
Many thanks for your help.
Mark Angus
I’ve checked your site and notice that in mobile devices Newsmag theme it’s inactive, that’s why the blocks are not displayed. Try to deactivate Jetpack mobile theme: http://screencast.com/t/EZIPMqxq, clear the cache, purge the cdn files if you’re using and test again.
Let me know how it goes.
