mobile site problems
Dear Team,
I installed AMP, but I have problems with mobile site.
how do i remove the Pulse Pro logo? https://is.gd/KOa2US (link to image)
How can I change the title in the footer? why can’t I see the content of the page? https://is.gd/ubyEu2 (link to image)
Thank you
Regards
First of all, we no longer recommend AMP because it is deprecated https://developer.bigcommerce.com/docs/storefront/wordpress/platform-integration/enabling-amp
To change the logo please edit with tagDiv Composer,select the header logo and change it => https://i.imgur.com/cR7F0v4.png -> https://www.youtube.com/watch?v=HXQQygkCCJo -> https://forum.tagdiv.com/add-logo-newspaper/
For mobile please edit with tagDiv Composer, select the viewport on phone, select the header logo and change it => https://i.imgur.com/cR7F0v4.png
When the mobile theme plugin is used, you need to set for pages the page content in the mobile editor using only the options from that editor – https://i.imgur.com/p8EqE1b.png. also, there is an option to disable the mobile theme from a page/post – https://i.imgur.com/d3kTBRf.png. This option appears in the Gutenberg editor. After you disable the mobile theme on the page, you can assign the mobile page.
Please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/
You can translate them from Theme Panel -> Translations -> Translations
Anamaria, thank you very much!
You were very clear!
With your answer I learnt many things: better than a manual.
Thank you again
Filippo
I’m glad. Don’t hesitate to contact us if you have other questions.
Have a great day!
