Good morning,
I’m using the TagDiv Newspaper theme and have a question regarding the mobile display.
I’m aware that there are two options for mobile devices:
The Mobile Template via Cloud Templates
The Mobile Theme using the AMP plugin
My question refers specifically to the Mobile Template, not the AMP version.
I have created two separate templates via the Cloud Templates:
– one Homepage Template for Desktop
– one Mobile Template for mobile devices
However, on many mobile devices, the Desktop Template is still being displayed instead of the intended Mobile Template.
How can I ensure—or force—that mobile devices reliably display the Mobile Template?
Thank you in advance for your support!
This usually happens with cache plugins. If the cache plugin does not have mobile support, the mobile version can be delivered instead. Please make sure that you have enabled the mobile cache -> https://i.imgur.com/W1KaV3U.png
Please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/
