I had posted this question 2 years ago. The issue still persists, however. When I use WP Super Cache as suggested by the answer from this question and others like it, either the mobile theme still works on mobile but appears distorted on the desktop version of the website, or the tagDiv Mobile Theme just does not appear on the mobile version of the website (which is currently the case).
WP Super Cache is installed with all the suggested settings. There are no other caching solutions on the website. Why is this happening?
An additional detail is that this issue only occurs on the home page of my website, not in any of the posts.
This topic was modified 3 years by
Paradoxer.
Correction: This issue actually extends to the rest of the website, not just the main page, upon further investigation. I have to disable the Mobile Theme plugin and remove WP Super Cache, putting back the SG Optimizer plugin back for now until I receive an answer. I need the mobile theme to work, however.
Are you sure there is no other plugin for cache on the website or host? Did you enable this option for mobile cache -> https://i.imgur.com/e9oMnQm.png?
Okay, so this is rather counter-intuitive, but what I have done to seemingly fix this issue for me is that, as I’m using SiteGround as my website’s host, I had to actually keep the SG Optimizer plugin installed and active, but disable the “Dynamic Caching” option in that plugin to make sure SiteGround was not using caching at all. Then, I enabled WP Super Cache with the proper settings, and so far there has been no conflict regarding the desktop version of the website, and the mobile theme works fine.
