Mobile Theme does not work with Multisite
Has anyone had any luck getting the mobile theme to work with multisite? It fails to find the correct path every time it is activated and no other plugins are installed. Any help would be appreciated.
You could try this solution provided by a theme user, maybe it will work for you
https://forum.tagdiv.com/topic/solution-mobile-theme-support-with-multisite-installation/
You’re the man Simion! I appreciate your help. It worked perfectly.
