check my site from mobile. https://playsiders.com
It has a white space on right side and is messing up the footer and header (they both displaying in wrong position).
Ok WTF mobile template is completely broke. I tried to delete it and it stucks as it is. What the fuck are you doing with the updates? I am losing my patience here.
CHECK THE MOBILE VERSION!
I managed to fix it by disabling cloud library and reenabling it. It seems it didn’t got updated if i didn’t do that. Why everytime your theme has problems like this? When an update comes out you mean that you fixed problems that you had, not causing new ones.
Try to do these steps:
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
Let me know about your results!
i downgraded and upgraded again. this fixed the problem.
