Mobile theme Latest Articles Ofset Problem
Hello, we have a problem with mobile theme latest articles ofset, when we select grid a category latest articles shows them in latests articles and if we put a ofset it ofsets from all posts… So we decide to make Grid All Posts and Latest articles ofset to the grid number 5 Grid 5 Ofset but what the main problem is when used pagination ofset number of articles shows in second page as they appear at first page bottom…
So second page dont show the correct… When ofset used…
https://haberton.com
Can you pls check… 20 Latest articles and check the last 5 of them and go to second page you will see 1st page articles in second page too 5 of them…
Usually this situation appear when you are using the mobile theme plugin and you have set an offset for the latest articles: https://i.imgur.com/vABNCKl.png
Please check this, also try to delete your cache(also from your browser) and let me know about your results.
Definatly, so you know the problem… Do you know anything to fix it? We delete the cache and tried many times…
I just explained above what to do. Did you tried it?
If the problem is still there, then please send an email at contact@tagdiv.com and provide wp-admin and Cpanel access so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
Yeap we tried everthing, we send an email, hope we recieve good news soon…
