Hi tagdiv team,
on my site the Mobile Theme is active.
When I test the site on a smartphone, I notice that the pagination does not work.
On the following page it says: “There was a critical error on your website”(Es gab einen kritischen Fehler auf deiner Website).
Can you help me with the troubleshooting.
Kind Regards
Axel
I just checked your website to see the reported problem with the mobile theme plugin and I can not find the problem, on homepage I see that you are using the responsive version https://i.imgur.com/KPstZ5w.png the mobile theme plugin seems to be use only for the rest of the website, but I couldn’t find the problem, can you provide some more details or a link where this is happen?
