Mobile theme plugin problem and View count problem
When mobile theme plugin is active, the menu on mobile phone does not work. I need help to fix this ASAP
Also, the theme is not recording correct views as the views recorded does not correlate with what is on google analytics.
The issue with the mobile plugin menu functionality could be caused by plugins, theme modifications or customization, these are to blame in most cases. I would suggest as a quick test to deactivate all non-theme plugins, then clear all caching. Check if the mobile plugin works as it should.
The theme will count the post views by actual page views, each time the page is viewed it will be added to the counter. Try refreshing the post page and check if the number changes accordingly. If you have caching then enable this option in the theme panel
– https://forum.tagdiv.com/ajax-view-count/
