Mobile theme problem
Here is a screenshot that shows how my website looks like on mobile:
https://www.screencast.com/t/TG09m1VRxv48
But when i click on an article the header menu gets changed to this picture:
https://www.screencast.com/t/4mp6Xamjev
how to fix this problem?
Thanks in advance
I believe that you are using the mobile theme plugin and not the responsive version from the theme. If is so, then please disable the mobile theme plugin, clear all cache and check again. The mobile theme plugin has it’s own layout and it’s allow only a few changes.
Let me know the results!
I disabled the theme plugin ( here is a screenshot)
https://www.screencast.com/t/PyPaMluu7
and i cleared all cache but my website shows me this:
https://www.screencast.com/t/he6Gp7CgiB
I believe that the website looks like that because you have the amp plugin enable and this is set on “Transitional”, please set it on “Reader” or please disable the plugin.
Thanks Calin
It works!
