Mobile theme problem
Hi i have some problem with mobile theme because it lost the style for example this http://www.sabanetasr.com/wp-content/uploads/2016/08/Screenshot_2016-08-30-16-06-45.png doesnt see like the correct homepage style. the correct is http://www.sabanetasr.com/wp-content/uploads/2016/08/14045424_1263535043687314_1765977916_o.jpg lost the style and an other problem is that views counter post takes to upgrade; for example desktop theme show that have 500 views and in the mobile thema only 172 Views.
Hello sainthilaire,
I have checked your website and I did not saw any problem with your mobile theme. Everything seems to work as expected. To rule out any conflicting plugins, please try to disable all the untested plugins, leave just Visual Composer to active, clear all your caches, purge CDN files if you are using the CDN system and install only the plugins that come bundled with the theme.
Hope this helps!
