mobile theme problem apache issue
I’m getting AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
I’m using contact form 7, Jetpack, visual composer and Yoast SEO plugin on my site. Can you please help me to fix this?
The site is running, but this error from the log. Sometimes the server out of resource for this issue.
Hello Aminul Islam,
Please keep in mind that the Mobile Theme is fully tested and it seems to work without any problems. Notice that until now we do not have any bad reports in this regard, sorry! Please try to make a new clean install from scratch via FTP way, install only the plugins that come bundled with the theme packet and rule out any conflicting plugins. For more references about this issue, you can check this -> https://wordpress.org/support/topic/ah00124-request-exceeded-the-limit-of-10-internal-redirects-due-to-probable-1/
I’ve fixed the issue. There is a .htaccess code error.
Thanks a lot.
