Hey there ,
I’ve installed the mobile plugin and when opened my website on mobile all it says is :
The mobile theme path couldn’t be set. Please check if you already have another mobile theme plugin active and disable it (ex. Jetpack Mobile Theme or similar). If you use a cache plugin clear it before checking the results.
I don’t have any caching plugin or any other mobile theme. I’ve made a child theme though but checked it and it seems all good.
Also, currently I’m Using a website maintenance plugin and for now i’ve disabled the mobile theme plugin but would like to use it.
Any help ????
You could try re-installing the theme, by FTP if possible, that could solve the issue
– https://forum.tagdiv.com/topic/mobile-site-not-displaying/
Do not enter any code in the theme files, deactivate the child theme as well after re-installing.
If there is still a problem, please send us an email at contact@tagdiv.com and provide admin login information as well as FTP access. We will investigate further.
