Hello I am still having a problem with the Masonry Grid on the mobile phone display. When I try it on an iPhone 5s on Safari and Google Chrome everything loads beautifully until the Masonry Grid where it displays off to the left in a thin column.
If you are going to test it I would appreciate you test it with my website which is http://www.rockshot.co.uk
I have tried the theme without plugins (leaving the Visual Composer). But it still does the same thing.
I am running Visual Composer 4.7.4 but I see that version 4.8 is available from the plug-in author but not through you?
I have had this problem for two weeks now and no fix in yet. I have not done any code adjustments or added css.
Can you please help?
S
The visual composer latest version will be available in the next theme update. Until then please use the version that is bundled with the them.
I have checked your website and saw the masonry grid error. Something seems to interfere with the theme’s JS: http://screencast.com/t/y3qzjEzv. Please undo any minification you have on your website as it is known to cause problems.
If the problem is still there please send us an email at contact@tagdiv.com with your login information so we can take a closer look at the problem. Please also include a link to this topic so we know who you are.
