What is the use of the mobile theme if it does not give actual speed? It shows so many extra CSS, request in PageSpeed. Help with Optimization. I have removed header ads so you can see actual theme code which decreases speed.
https://globaltechgadgets.com/
Please take a look to our demos that is using the mobile theme plugin -> https://demo.tagdiv.com/newspaper_local_news/ this one do not have any extra optimization for pages speed.
You can make this quick test, disable all extra plugins and let only theme plugins (eventually you can let the plugins for optimizations) cleat all cache and check the pages speed, also after that you can make one more test without ads, sometime the problem is that is take a longer time until these are delivered from external links.
Let me know the results!
Hi Nagarig, that means that there are still some elements that are not compatible on mobile theme or there are other elements that are slowing the mobile theme version.
As I can see now you have 53 for mobile theme -> https://i.imgur.com/rz93D1S.png but this is move more faster then 53.
