Mobile theme translation problem
all the fields were translated at Theme Panel->Tranlations into russian but
in mobile theme there were still few untranslated parts, for example:
“no comments”, “latest articles”, “about us” etc.
Could the translation be done inside theme code somwhere?
As I understood there is special file for mobile theme translation named ru_RU.mo.
But how to change itexactly?
The theme panel translations will apply in the mobile theme as well, for example
http://prntscr.com/o3ppfqhttp://prntscr.com/o3ppjn
http://prntscr.com/o3pptohttp://prntscr.com/o3ppzl
Do you maybe use a translation or multilingual plugin? For example if you use WPML the theme panel translations will not be used – http://prntscr.com/o3pqzx
No WPML…
But somehow when I put at the same field the same words it worked and now it’s OK! …without any cash clearance.
