Hi Team,
We are facing issue with mobile view in Big Grid Flex 5.In mobile view we get slider. It should not be there.Please check below screenshot for current look
What we are looking for is
Can you please suggest something ?
Edit the page with TagDiv Composer, click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB ; there you can see your mobile version and you can edit the elements there in order to display how you want.
Hey Bettina,
We know where those mobile settings are.
We want to get rid of that horizontal scroll bar which appears in mobile view. Posts should appear one below another.There is no such setting to achieve this or we are missing something.
Please check main question for our requirement.
It’s not an issue, this is how the Big Grid Flex blocks were designed, with that scroll bar on mobile.
All blocks Big Grid Flex have this option, if you don’t like it, you can change the block with another block, like Flex Block=> https://i.imgur.com/mlVSboN.png
Hi Anamaria and Bettina,
We cannot remove Big Grid Flex 5. Desktop version of website is kind of finalized. Now Desktop layout cannot be changed. Now at this stage if you ask me to use another component,it would affect our go -live date. Also there is no mobile page associated with our current page. Its handled automatically
What I need
1> No need to change Componenet. I will have to use Big Grid Flex 5 in any condition
2> In mobile view that scroll should be removed.Posts should appear one below another.
Unfortunately, you can not customize the way is looking this element from settings(change the position of the modules,etc), that’s why we have a lot of types of elements.
For customization and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
We are sorry for the inconvenience!
Thank you for understanding!
