Mobile view problem
On mobile phone LG G4 that i have for testing i noticed that homepage is not displaying correctly. Im using stock internet browser from google (not chrome – in chrome its opening fine). 123
Is there any way to fix this?
The theme wasn’t tested with this browser so it’s possible to appear some issues with its functionality. However I’ve test your site on the default android browser and it loads fine. I am not sure wy isn’t loaded correct on your side but you can try to clear phone’s cache memory then test again.
