My website http://asiasamachar.com is complete but all I can see are codes when viewing the website from a mobile phone. See here : http://imageshack.com/a/img673/4597/vAR2PP.png
How do I fix this issue?
Thanks,
Habhajan
Any solution? Need the site to be fixed asap, thanks.
Hello habhajansingh.
I have checked your site and it seems that on the mobile version your theme changes to “Minileven”
http://screencast.com/t/mi9NQX4Nwt
The code you see onscreen is visual composer code which cannot display properly.
Try to disable all of your plugins except visual composer and see how it works out.
Hello Bogdan,
I’ve deactivated all plugins and only kept visual composer on. I still see codes. Please check it out.
Hello habhajansingh,
I did a bit of digging for your problem and it seems it’s related to the Jetpack plugin:
https://forum.tagdiv.com/how-to-manage-the-mobile-theme/
