Modal Pop-up does not work on mobile theme
The site can be found here
I have the TagDiv mobile theme plugin activated and it does not appear on the mobile version.
I would apreciate a solution for this if possible.
Please let me know if you use our element for the pop-up.
Unfortunately, for the mobile theme, if you use our element for pop-up then this is not available.
I am using your element.
Is there a workaround regarding this?
Maybe a plugin or something?
Unfortunately, for mobile theme no.
I don’t know a plugin, but if the modal pop-up is on the homepage, you can disable the mobile theme https://www.screencast.com/t/axXRJsWby, and use it for posts/categories, etc.
