Mode-Less and Text.js problems still continues…
Still, What ever i tried, reinstall Theme, Deactivate all plugins, reinstall td-composer nothing works… These errors seems not moving anywhere… (Only logged in) When logged out seems no problem…
Failed to load resource: the server responded with a status of 404 (Not Found) /mode-less.js
Failed to load resource: the server responded with a status of 404 (Not Found) /snippets/text.js
I guess i tried everything , is there a chance that you can login and check if i am making any mistakes…
http://sonsoz.com.tr
This problem is in all pages…
Please help me…
  • This topic was modified 9 years by Smanchi.
I sent you login details via contact email… Pls help…
If you have sent us an email with admin login credentials we will take a look, and reply by email.
Did you get this solved? I have the same issue. I have Yoast SEO but even when disabled, the problem doesn’t go away.
@JayVee Please provide more details about the issue you are having, the result of the investigation in this topic was inconclusive.
