Hi Team,
I want to achieve below things in the first post that is displayed on the page (wide banner) in Category top post style Grid full 1
1.It should not be top post. Post should be the one that has tag ‘xyz'(this tag will be only on one post always for any category) in that category instead of post that is displayed as top post.
2.I want to have the Subtitle and quote of the post tagged as ‘xyz’ in the area.
Please let me know if this is possible with existing functionality or do i need to add any customisation in this style template?If yes then where to add the code?
Thanks! 🙂
Hello Sagar90k,
Unfortunately, the theme does not have any such an option that allows you to achieve something like this with the actual Big Grid Full functionality. You need to customize it yourself through the code from the theme core files and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide additional customizations at the moment, sorry! As a hint, you need to edit this core file from here -> https://www.screencast.com/t/cRLSnp97g0L If you want to edit Big Grid Full 1, as for example, check that core file.
