Module 8 does not load the posts properly in Category page. After 10 posts the section is getting broken and posts are coming in new row.
Screenshot https://i.imgur.com/OV85YWU.png
Please find it here – https://www.insidecryptocoins.com/category/guides/
That happens because you have set in Settings > Reading Blog pages show at most 10 posts
( https://www.screencast.com/t/sKj7LI2tuJ ).
But now I see you are using cloud template.
If you have set 3 column and there are 10 posts when is load start a new row, in order to look good you need to set a number that is divide with 3.
https://www.screencast.com/t/oXw7vrD9b7xc
https://www.screencast.com/t/LLft4Bk5q
