Module Border Radius in Flex Block 1
Hi, I am unable to find any option to set a radius for individual modules in flex block 1. There’s an option for the radius in post loop but I can’t use that because it’s doesn’t have any filter for the categories.
That’s so strange not to give the feature for radius on flex block module which is meant to be the most flexible choice but post loop which is pretty much pre-defined.
Hello !
This option is available on the Flex Block 4 as you can see here: https://www.screencast.com/t/6mPVmfaKh
I hope this was helpful !
Oh really? Then show me how would you set radius on the individual module in flex block 4? Also flex block 4 only shows 2 articles in the larger module the rest are just displayed under them. Please read my query again and THINK what I meant.
What I want is display articles in a masonry grid and set radius and background to individual modules and filter them with categories. See this screenshot. I used post loop for this example but the problem is I can’t filter posts based on categories, it will fetch all the latest posts. I don’t know why you showed me the example of flex block 4 with border. When did I ask for the border?
Hi pratiek,
Indeed the flex elements do not have a border radius for the module, only for element from the module, in order to set the border as in your example you need to edit the flex block and to use this custom css -> https://i.imgur.com/hJBMcWz.png -> https://i.imgur.com/VWwgIyN.png is possible that for some settings to need to be adjusted the css, if you need help with this, lease provide me a link to your website where I can create the right css.
