Module fonts customization
I’m trying to modify the title font size on Tagdiv > module 14 fonts but although changes seems ok on preview panel, they are not applied on browser live preview. I’ve tried to edit it on Newspaper – Theme panel > theme fonts > modules and blocks – article title but there aren’t no changes too.
Please help.
Regards,
JM
It should work, I made a quick test – http://prntscr.com/nzxqpb If the panel saves the setting, then it should apply. Could be caused by caching, try to clear the cache if you use any. Also force refresh the page where you are checking (Ctrl+Shift+R).
If the problem remains, post a link to the page where I can check it. Let me know.
