More Article Box – Default Title is wrong
Hello Dear TagDiv-Team,
i am using the more article function and it is working.
The only problem though, the theme shows a default title which is the same for all sites#
and was not created by me. This is the title:
“XMehr Nordic Walking entdecken”
Question: How can i edit this?
Please see the example live on the site:
http://www.linkanton.de/grosse-groessen-mode-mollige-plus-size
Thank you in advance!
Best Regards,
Christian
You can edit that text on the more articles box in Theme panel->Translations like this – https://www.screencast.com/t/w41QXMVc and change it to what you want
Hi Simion,
thank you. Just changed it and it works now!
I checked the translations while setup, though not to the end …
Regards,
Christian
