That should not happen, the X icon simply closes the more articles section. It cannot be made to redirect by a theme setting or in any way, it is not a link.
Inspecting your website I see it is a link and directs to a website
– https://www.screencast.com/t/3rhiRQZt8
Please check if you made any modifications to this file, either directly or by a child theme maybe
– https://www.screencast.com/t/yKqKj4nM
Something is causing this issue, from what I can see there are a lot of links leading to the respective website, in a post page I checked on your website
– https://www.screencast.com/t/HkNHwW7deDm
There are links after links that would serve no actual purpose the page while checking with the inspector, not in the page source however
– https://www.screencast.com/t/b8qK1ZgBmoB
So maybe a plugin could be responsible, or maybe code entered in the theme panel (please check all the code you entered in the theme panel sections) or theme files, or possibly modifications made in them. Links are being generated in the post page leading to that website, but I could’t say from where this is coming from.
