More Article Box not showing on mobile
I have activated MORE ARTICLES BOX in POST SETTING but it is showing on desktop but not on Mobile
The more article box will be display on responsive version of the theme, so if for you is not display, then most probably you have enabled the mobile theme plugin.
In this cane if you want that article box, you’ll need to disable the mobile theme plugin or use it only for amp.
https://tagdiv.com/mobile-theme-get-mobile-ready-with-newsmag-theme/
Mobile theme and amp version both are active https://india24x7.news
Hi Harpal, like I said above, if you are using the mobile theme plugin the “more article box” will not be display.
This can be display only for the responsive version.
SO if you want to use it, you need to disable the mobile theme plugin or use the mobile theme plugin only for amp -> https://i.imgur.com/7plgoEe.png
got it, thanks
