I’m having an issue with the “more article” box not showing up on posts. It works fine on the homepage, but not on post pages. The homepage is set up tag-div composer, but the post pages are set up using style 8 of the default post templates.
I’ve tried all of the different options for the display articles options (from post tags, etc), but am still having the issue. It’s not an issue of whether there are enough posts to display, as there are plenty in each option.
The site is rvhive.com
I deactivated all plugins, and I still had the same problem.
Can you please help figure out what is going on? Thank you
This option works only on the posts, not on the homepage. https://i.imgur.com/kYnc03x.png
