More articles box can be small?
Hello
How I can make it small? It is always big and close some part of ad
http://prntscr.com/r3f671
Any solution?
Hello !
Unfortunately that is not possible with Newspaper Theme.
Thank you for your understanding !
So when I use smart sidebar articles box is bad for the site??
Hello !
That is a taste thing. If you and your users like it. You can use it, if not, you can disable it.
