Sorry if this answered, but the forum is hard to navigate. I have a new newsmag site and I have activated the more articles box for the desktop and it works fine. I can click on the x and the box disappears. But when translated to tablet or phone, the x will not let me delete the more articles box after it appears. The number of posts to display is clicked at 1 and the disable time is 1 day.
thank you
here is my site: http://wordpress.todayshospitalist.com/
I’ve test the more article box on my side and works fine on mobile devices, if I press X the pop up window close down. Try deactivate all plugins except Visual Composer, clear all caches and test again.
Also I’ve tried to accesses your site but it’s not available: http://screencast.com/t/u6UmtxUea
Let me know how it goes.
Thank you for the suggestions. I did as you said, and it worked…we were also having a problem with images appearing on our phones/tablets.
However, after I deactivated and cleared and saw the items needed, I then reactivated the various plug-ins as I believe we need them? and it went back to the same problems; i.e. can’t x out of more stories box and images do no appear.
Here are the few plug-ins we are using: BackupWP, Regenerate thumbnails, WordPress popular posts, WPRetina, WPbakery and Yoast SEO.
Our site is not live yet, still in testing, perhaps that is why you can’t access?
I am relatively new to WordPress, but I thought all themes would run with plug-ins?
thanks for any more insight you can provide.
Indeed the WordPress themes should work with various plugins, but however in same cases appear conflicts between some scripts which causes issues. You should chose very carefully what plugins you’re using and how they will affect them’s functionality and also site’s performance.
From the pluginss that you mentioned we recommend only Regenerate thumbnails and Yoast SEO. The others aren’t tested with the theme and I am not aware of theirs functionality so I can’t say how will work with our theme.
