Hi, after the last update to the “London news pro” template, the “More articles box” has disappeared and its menu of options in the “Theme panel” of Newspaper has also disappeared, as you can see in the attached screenshot:
On the web: https://www.leyendasdetoledo.com
Any solutions? Thank you!
Hi, thanks for the answer but I don’t want to use “Standard Pack plugin”, because according to you, it causes a lot of resource load on the web and penalizes the speed of it. I have therefore switched to using only the cloud templates and disabling the “Standard Pack”. Is there another solution?
The only way for having the more articles box is to add “Flex Block 1” element with TagDiv Composer. Apply a filter into the element like this: https://www.screencast.com/t/LzmlAPPO ; select the row and add these settings like in this screenshot: https://www.screencast.com/t/MrmnTfQs7Gf
After this, you will have more articles box sticky at the bottom of the page, but then you need to customize the design by yourself.
Hope that helps you!
