More Articles Box not showing on mobile
I have the more articles box enabled in the theme panel, however it does not show on the mobile site when I access it from my phone. I just want to confirm is it disabled as a whole in mobile. Is there any way to force it to appear it on mobile?
The more article box was not designed to be displayed on mobile device. It is hidden via css – http://screencast.com/t/Gc2fcp1g
If you want to enable it you will have to edit the style.css to remove this code – http://screencast.com/t/UsMckM1mR
Or you can overwrite it using more specific target – http://screencast.com/t/jckIue23X50x just paste this custom css in Theme Panel > Custom Css and it should appear:
.single div.td-more-articles-box {
display: block !important;
