MORE POSTS DON'T LOAD FROM PAGINATION TO MOBILES
Hi.
I’m using paginations [next-prev ajax] to all my blocks on frontpage. They work fine to desktop but more posts don’t load to mobile.
Same problem to more articles of posts.
(www.tameteora.gr)
Actually the pagination does not work on desktop as well
– https://www.screencast.com/t/OvtxcBob
Checking with the browser inspector console it seems that the theme request of the admin-ajax file is denied access by the server
– https://www.screencast.com/t/lHxuFrZ9iWP
In most cases this happens because of security plugins or security modules of the server, or firewall. I suggest you check with your hosting and mention this to them, they should be able to help you with this.
