More than 2 sources per post?
If I have a post that uses multiple sources (i.e., more than 2), is there a way I can continue to add them? Would any potential solution be able to accommodate an unlimited number of sources, or is there a maximum allowed?
There is no limit for the source and via fields, you can see here how those filed were added, use the same method to add more.
Hope this helps!
Thanks, what do I have to edit in order to add more slots in the post editor so that I can easily input more sources?
Try to edit the td_module_blog.php file and add another source and via filed like this: http://screencast.com/t/sQVGkP5OWY
