Hi, im using a most viewed or most visit block on my website, this block is taking data from Jetpack. My problem is that im not going to use anymore this plugin and i don’t know which other plugin your template is compatible with (related to views/visits).
Can i use any other plugin or can you recommend me one? i still want to use a most viewed area somewhere on my site but to be honest, jetpack is not the best choice.
Thanks in advance!
I think that you can use one of those options -> https://i.imgur.com/Xa8zFbm.png enabled the module from the theme panel -> https://i.imgur.com/YhrxEKs.png
I hope this will help to replace the filter that you used.
Ok Thank you!
Here is the thing, my website only have 3 admins and the other day i found this weird link in one of my empty blocks (not in use). You can see the pic
Did you guys include any type of ad that im not aware of, i just removed it, it wasn’t placed by any of the other admins because they dont even know how to do it (only me). What that could be?
