Dear Sir,
Could you help me to move comment section to over all comments to avoid scrolling to last comments.
Eg:
My article: https://tuhocmmo.com/10-nha-cung-cap-hosting-wordpress-tot-nhat-nen-dung-hien-nay.html
Thank Sir,
Hello alexraymonds,
You should edit the theme core files and edit the code from there if you want to achieve as you wish. -> https://www.screencast.com/t/I6B8Q9s3Bu8T
You can only achieve this by altering the files. Each post template has 2 files corresponding to it. You will have to move the comments code from one template file and move it below the related articles in the other template file.
Here is an example of the default template:
https://www.screencast.com/t/LspHG5PLg5y and then paste the code in the loop single file directly above the related articles and wrapped in php tags: https://www.screencast.com/t/lsdEqVgA8Z1
Sorry, if you want to change the order of these elements notice that you should change the HTML structure for this area. It’s not a simple task and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry! As a hint, please edit this core file from here -> https://www.screencast.com/t/jm1xXtscbf
