Move Comment Section
I want to move the comment section on Single Post Template 5 above the related articles & next previous post for the post template. Can anyone point me in the right direction?
In order to achieve that you must edit the corresponding loop single file to your post template style you use, in your case loop-single-5.php found in the theme folder. You must insert the line of code responsible with the comment section – https://www.screencast.com/t/aUBBxLCZwxfr in the loop single file, as by default it is always at the bottom of the single post page after the loop, like this – https://www.screencast.com/t/NmmkkwebIeN above the next/prev article like you want. This is the code I used
<?php comments_template('', true); ?>
Result – https://www.screencast.com/t/DK20YIvmX
