I would love to get some help here, in older version I had of NewMag it was ok and after installing the newer one i’m facing problems now.
I want to main side bar of the site to go to the top (above the content) instead of below it.
Please help by providing a css solution or something that could work here…I can’t just hide it in desktop and put the content for mobile because it includes ads and hiding them is against terms.
My sidebar is already set to left side and still it doesn’t work.
you can see a sample page here:
https://viralwiz.com/six-dead-at-hollywood-florida-nursing-home-after-irma-cut-power-mayor-says/?utm_source=$PUBLISHER_ID&utm_campaign=300b&utm_medium=$DOMAIN
Hi Catalin,
You can look at this page I sent as example:
When looking in desktop version you can see the sidebar loads to the left of the content which is ok – screenshot here: https://imgur.com/a/NZllR6P
But when I minimize the width to look more like mobile the sidebar moves down below the content. screenshot here: https://imgur.com/a/JqzX2Bk
I’d like the sidebar to be above the content in mobile so it would be directly below the header – here: https://imgur.com/a/1WEElTH
Hope this helps in better understanding.
Unfortunately, the theme does not have any such an option that allows you to make these changes, sorry! You need to customize it yourself through the code and if you are not aware of the steps which are needed to take in this case, please consider hiring freelancer/developer to help you! We cannot provide custom work at the moment, sorry!
