I’m using the MultilingualPress plugin by Inpsyde to handle the multiple languages on my site. One of the features is that it puts a link in the post to the translations in other languages. This was working fine until I switched themes to Newsmag. Now when a post has a featured image, the link doesn’t show up.
So here is an example of where the link does appear.
And here’s one where it doesn’t.
Any suggestions on how to fix this?
Unfortunately the plugin is not tested to work with the theme and we cannot guarantee it will work 100%. We have not tested this plugin and we have no idea of the plugin functionality in order to provide an answer.
I’ve checked you’re the posts that you provided as examples and noticed that if you’re using a feature image then the plugin does not generate any content. I suppose that there is a condition in plugin’s code which cheek if the post have or not a featured image and depending by result display its output.
Unfortunately time does not allow us to provide plugin implementation support. If you really want to use this plugin we suggest you hire a freelancer to help you with implementation. You can hire one from studio.envato.com
