Multiple Background ads with their Click Ad
Hello there!
I like to know if there is a way to create multiple Background ads with their Background Click Ad. Is it possible?
Thank you
The theme was designed to display only one background click ad. To change this functionality are required lots of customizations in theme’s ad system. This is a complex task which involve good coding skills and if you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you as we can’t offer customization services at the moment.
Thank you very much for that very clear and satisfactory answer. I’m glad to have you whenever I encounter a problem of understanding or information.
Problem fixed
