I’m trying to have multiple loop post elements on Category and Author pages. Started with a blank template. Inserted in 2-3 “loop post” elements so that I could have different sections with different sized elements for the loop. I offset the additional posts as appropriate. The template looks fine. But when I implement on the site, the same posts appear in all sections, or sometimes it is the same single post repeated in each section. Pagination does show (as there are multiple posts), but each post repeats in all sections.
I saw a similar post here but wanted to start new thread since that one hadn’t been updated.
Essentially the loop is broken when multiple “post loop” elements are on the same page.
I was curious if a fix has been identified or if there is a workaround in place.
Thanks. I’m assuming you meant to say “can’t” instead of “can.” Do you have any ETA as to when this functionality may be fixed?
This is my website the main content is always repeating on every section, article of my pages
I’ve checked your website and now it look normal -> https://www.screencast.com/t/R6haXrctZf maybe you had set in the footer the homepage as a footer page.
