Multiple loop problem
Dear support,
i’m trying to use, on a category template built with the tagdiv composer on Cloud Templates, two post loops: the first one has an offset parameter set to 4, the second set to 7. Unfortunately, the second loop block, no matter which setting i apply, always inherits the first loop values displaying the same posts as the first block. It seems like there is no wp_query_reset() o wp_reset_postdatA() set.
Can you please advice? Thank You.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
We have the same problem – is there already an official solution?
Hello !
Having 2 post loops on the same template is not possible in Newspaper Theme.
We are sorry for the inconvenience !
Thank you for your understanding !
