My comment no work!!
I have disabled the options ” DISABLE COMMENTS ON PAGES ” and ” DISABLE COMMENTS sitewide ” does not work. Not to do to make it work .
blog.ledbox.es
Have you managed to solve this as I have checked your site and haven’t seen the comments section neither on pages nor posts: http://screencast.com/t/99fdwBbNZ
True, the module does not appear comments . I do not know why.
I activated the module but does not appear
Are comments also enabled in the WordPress settings under discussion?
@alvaro
Please make sure that you have them enabled in the WordPress settings under discussion and if still do not appear please make sure that you check this without any plugins active and also makes sure that you empty all cache/purge files if you use any, and try again.
