My menu in homepage need more than 20 second to load.
The main menu in my homepage need more than 20 seconds to load while on another page it normal
Hello !
Please provide a link to your website in order to inspect.
Hi, I have fixed it. However, I meet a new problem with megamenu.
I have inserted a category but it not show a post
https://imgur.com/a/C4EIjxy
Here is my website :
https://newlifeimmigration.vn/
Hello !
Please make sure to add the new category into the menu too as you can see here: https://www.screencast.com/t/eGzQwRNfE
I already add the new category to the menu. But nothing change
Hi alotoinghe,
Please make sure that you set the category in the menu that you have selected, also not that you need to have posts added in that category.
Also if there is still a problem, please provide some screenshots with the settings you’ve made.
Mega menu -> https://forum.tagdiv.com/mega-menu/
Here is my screenshot
https://imgur.com/a/fLmJOJD
The td composer is disappear
https://imgur.com/a/6UpKx3h
Hi alotoinghe,
As I can see in our screenshot the mega menu is not displaying right, this it should look like this -> https://i.imgur.com/fawv6jH.png not like this -> https://i.imgur.com/huLxLLd.png make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Please note that a cloud footer can not be edited from backend, only from frontend, using tagDiv Composer, for example, you can edit the homepage, click on edit with tagDiv Composer -> https://i.imgur.com/uweNRrc.jpg after that go down to the footer end edit it how you want (now you can customize the the whole web-page from fronted).
Let me know the results!
