My posts have lost their spacing
If I look at one of my blog posts, it doesn’t have like breaks or any spacing. Sometimes if fixes itself when I refresh but eventually goes back to not having spacing at all.
See this:
https://www.interestinganswers.com/history/why-are-prescription-drugs-referred-to-as-rx-drugs/
If I refresh it looks like it should:
Notice the spacing between the paragraphs.
This is the page used in this example:
However, it seems to happen w/ any post.
Hello !
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv and Yoast ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Thanks. I will try these things!
Hi Ryansmccain,
I just checked your website again and now is look normal -> https://i.imgur.com/3CDzLXb.png -> https://i.imgur.com/yZgvo3x.png
Let us know if there are still some problems.
Have a nice weekend!
Thanks. I have no idea what happened. Perhaps another plugin caused the issues.
Yes, this is possible, something was there if it was not displaying correctly, but the good thing is that no is ok.
