MySQL Problem
with your template i have many problems with MySQL (sleeping queries)
Do you have other cases like mine?
Thank’s
  • This topic was modified 11 years by capiraso.
All the quries are made from wordpress, the theme doesn’t make direct queries to the database, so I don’t think that it is a theme issue. From what I understand it is normal to have some open connections, unless they are in the hundreds, so the wordpress will easily connect. Please check this topic, it may help – http://stackoverflow.com/questions/10363160/slow-mysql-performance-sleep-queries
