Need a theme for creatives that features author name over post title
All of the themes you offer feature the standard blog title -> author name format. However, creative publications typically care less about the post title than the author name. Check this out, for example:
https://www.aprweb.org/
So I’m looking for a theme/style that puts author name on top (for multi-author blogs) and post title on the bottom. Can I do that with your themes?
Hello jauburn,
Sorry, but the theme does not have any such an option for this, unfortunately!
Is there a custom CSS modification you could give me that would put author name on top and blog post title below?
Hello jauburn,
If you want this such a customization, notice that you should implement it yourself and create the custom CSS code according to the following useful guide from here -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/ If you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
