Need Following Container Info
What would I put for each of these?
http://i65.tinypic.com/16747z5.jpg
  • This topic was modified 10 years by sfeaton.
The css selectors for the containers that you indicated are:
-content container: td-container or td-container-border
-post tile selector: entry-title td-module-title for pages/modules and entry-title for posts
-if you’re referring at post paginations the container is: page-nav-post
-comments container: comments this is for the entire comments section, for each comment the selector is comment followed by an unique id: http://screencast.com/t/GSDMhvr7n
IF this is not what you mean please provide more details.
I was unable to get this plugin to work with that info. https://wordpress.org/plugins/auto-load-next-post/
Would this plugin work with the theme at all?
Unfortunately the plugin is not tested to work with the theme and we cannot guarantee it will work 100%. We have not tested this plugin and we have no idea of the plugin functionality in order to provide an answer. Unfortunately time does not allow us to provide plugin implementation support.
If you really want to use this plugin we suggest you hire a freelancer from sites like http://studio.envato.com/ to help you with implementation.
Thank you for your understanding and for your message.
